Another Vacuum QUESTION???
Old Jan 2, 2010 | 05:30 PM
criptic22's Avatar
criptic22
Default Another Vacuum QUESTION???
First off thanks for looking.....
I have looked for 2 days trying to find what i need looking through old posts but have not been successful.
The Vacuum (TEE) that is on the bottom of the upper intake manifold
has a cap on it,(the nipple that is facing the firewall) is that cap supposed to be there? My biggest issue is that there is oil blowing past that cap and is saturating the driver side valve cover.
If it is supposed to be capped why would there be enough oil blowing past to saturate the valve cover? Any help would be appreciated thank you.
Old Jan 2, 2010 | 06:17 PM
87FoxStang's Avatar
87FoxStang
On that "T" I belive that 1 side is suppose to be capped, and the other goes to the PCV valve.
Old Jan 2, 2010 | 07:05 PM
criptic22's Avatar
criptic22
Ok, when my wife gets back in going to take i look and make sure cause my pcv valve is not connected to the tee
Old Jan 2, 2010 | 10:11 PM
ALMOST STOCK's Avatar
ALMOST STOCK
It should look like this.
Old Jan 14, 2010 | 01:12 PM
criptic22's Avatar
criptic22
Sorry for the long delay but my fuel pump went out so i had to take care of that. but thankyou that is exactly what i was look ing for now i just need to take off the manifold and do it.
Old Jan 14, 2010 | 01:26 PM
Tony71502's Avatar
Tony71502
If oil is blowing past the cap then why not get a tighter fitting cap?
Old Jan 14, 2010 | 01:39 PM
jkrum10238's Avatar
jkrum10238
+1 fix the cap
Old Jan 14, 2010 | 02:25 PM
dreamer1uk's Avatar
dreamer1uk
Hi,
Once you have the PCV system hooked up correctly, id deffinately replace the PCV itself as when there clogged, you will get blow-by coming from other parts of the engine. Looking at an air filter and seeing oil on it is a good sign of a clogged PCV valve or an inopperative PCV system .
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
