4.10 gears...
4.10 gears...
i bought my mustang with 4.10 gears in it already.. i was wondering if it is normal for my car to shake/sputter hard if im going under 60 in 5th gear.. and 4th gear if im going under 40? or could it just be my motor shaking since i do need to put in new motor mounts?
it is not normal at all.....
what are your rpms doing when it shakes??? i doubt the mounts are bad...but if they are new ones probably won't help unless they are completely shot
get the energy suspension ones... the poly ones, and do the trans mount too... i think you get a good deal if you buy the combo
the sputter could be a fuel problem. cloged injectors, something clogging up the lines. water in the gas. the shake could be your driveshaft of wheels need to be balanced. check your lugnuts too. they could be loose causing the shake
junior04
09-28-2015 10:53 AM
Figure8allday
08-22-2015 11:11 AM
