starting problems
Old Jan 5, 2010 | 12:40 PM
hotstang97gt's Avatar
hotstang97gt
Default starting problems
i have a 93 LX converted to carb. some time when you go to start it. the car wont start. it sounds like the battery is dead. ive changed the battery and alternator and its still doing it. one of the wires going to the solinoid on the fire wall. it would heat up if you hold the key over for a few seconds. could it be that wire causing the problems?
Old Jan 5, 2010 | 12:59 PM
Tony71502's Avatar
Tony71502
The only way that wire would be the problem is if it was changed and is undersized. If there is too much amperage in that wire causing it to heat up then something else is the problem I would think.
Old Jan 5, 2010 | 02:45 PM
zebo87's Avatar
zebo87
does your starter grind or struggle to turn the engine over. that might be problem. the undersized wire sounds like one issue.
Old Jan 5, 2010 | 04:02 PM
1988TTOP's Avatar
1988TTOP
man i have the same ****ing issue if u fix it let me know i have replace the cable that goes from the starter to the relay the starter and the stater relay and it still dose it
Old Jan 6, 2010 | 10:31 PM
hotstang97gt
i changed that wire and it started up nice. it didnt want to start for me once today. got some jumper cables on it and it started right up. i dont think i completely solved the problem but it deff helped alot
djbigskrilla
Sep 20, 2022 01:04 AM
jjwinel78
Aug 17, 2015 03:34 PM
cvarner131
Aug 17, 2015 07:38 AM
KEM Motorworks
Aug 14, 2015 10:13 PM
Pain.
Aug 7, 2015 10:48 PM
