car shakes at 3k+ RPM
i have a '93 mustang gt and it starts shaking when i rev past 3,000 RPM when its in gear. if its in neutral it's fine, but when i'm driving the whole car shakes.
because of this, i shift before 3k which really hurts my acceleration, like my friends VW passat could beat me because i have to shift so early.
my mechanic thinks that its the flywheel and it needs to be resurfaced.
but he said since i'm learning to drive stick on the clutch i have, then i should just wait til the clutch burns up and when i have a new clutch put in, i will just have the flywheel resurfaced at the same time.
ok, so my question is this, is it probably the flywheel? could it be anything else? just out of curiousity.
i know that if it was the driveshaft then it would shake all the time, and if it was the universals then it would shake whenever i take off or start moving.
It kinda sounds like the problems I was having with mine before I put it up for the winter. My shifter would start vibrating at 2800 and got dramatically worse after that with some noise. I won't know what's wrong with mine until spring.
ShaneB26154
35
03-04-2021 04:05 AM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
