5 lug swap from a 02 can it be done
Old Jan 11, 2010 | 08:27 PM
sleeping stallion's Avatar
sleeping stallion
Default 5 lug swap from a 02 can it be done
i have my 02 gt sitting in the drive way and want to swap out everything into my 90 coupe 5 lug motor trans rear end everything. i tried doing the front 5 lug swap for now just to roll around but they dont line up right what can i do. pls guys help me out
Old Jan 11, 2010 | 08:31 PM
motorman524's Avatar
motorman524
MF Informant
Why are you swapping everything to the coupe? What isn't lining up?
Old Jan 11, 2010 | 08:47 PM
sleeping stallion
just wanted to have more fun the 2002 is down got a lil behind on tags and car ended up getting hit on the door car went 11.6 on that heavy car so i wanted to drop in everything in the light coupe. its a 2.3 now. when i put the spindle on and everything the hub goes in toward the motor it looks like the thing is face toward motor instead of straight. i been reading up a lil and some say put a spacer but i dont no.
Old Jan 11, 2010 | 09:17 PM
motorman524
MF Informant
On the spindle the only difference should be a shorter ball joint stud and the steering arm is lower which requires a bumpsteer kit. It should work fine though.
I like your idea
Probably won't see what as much gain as you think though. That is a lot of work.
Old Jan 11, 2010 | 09:21 PM
sleeping stallion
where can i get that ball joint any idea. just going with something different you no. what is longer
Old Jan 11, 2010 | 09:25 PM
motorman524
MF Informant
You just need two hardened 5/8 washers per side to take up the extra space.
Some people also suggest hardened ball joints with this swap. There are lots of Mustang parts suppliers out there. AM, LRS, CJ Pony ect.
Old Jan 11, 2010 | 09:26 PM
sleeping stallion
so u think with those 2 5/8 washer it will sit right
Old Jan 11, 2010 | 09:48 PM
AdderMk2's Avatar
AdderMk2
Banned
probably not... why dont you just get the SN95 balljoints?
Old Jan 12, 2010 | 03:17 AM
motorman524
MF Informant
I used this as a reference when doing mine:
http://www.mustang50magazine.com/tec...t_install.html
It was a 51/48 washer.
Will a sn95 ball joint fit in the a arm? If so, do that.
Old Jan 12, 2010 | 03:40 AM
motorman524
MF Informant
All you are trying to do is add height.
