MASS AIR
Old Jul 25, 2005 | 11:20 PM
BADNOTCH's Avatar
BADNOTCH
Default MASS AIR
I bought a C&L 76mm mass air meter out of a 95 mustang. Will it plug right in and work on my 89 stang? It is already calibrated for my size injectors, so thats not an issue.
Old Jul 25, 2005 | 11:26 PM
uedlose's Avatar
uedlose
Default RE: MASS AIR
just unbolt the sensor off the top and bolt your sensor on cuz the 95up electronics are diff. then the 89-93.and it should be ok
Old Jul 25, 2005 | 11:43 PM
BADNOTCH's Avatar
BADNOTCH
Does the sensor have anything to do with the calibration? Because the new meter is calibrated for 24lb injectors, and my stock meter is for 19lb. Swapping the sensor souldnt affect that should it?
Old Jul 25, 2005 | 11:57 PM
uedlose's Avatar
uedlose
No the sensor will not change any thing on the C&L they change the small tube in the meter for the injectors calibrations.now the Pro-M meters change the electronics for the injectors as the the Granatell meters are also calibrated with the electronics cuz they were made by Pro-M
Old Jul 26, 2005 | 02:30 AM
Quik's Avatar
Quik
i think the sn95 ones are mounted differently and are different.
Old Jul 26, 2005 | 08:54 PM
wildstang87's Avatar
wildstang87
exactly what uedlose said, the c & l meter uses the sampling tube to calibrate for the inj. size, the stock electronics work. just swap the electrical part.
Old Jul 26, 2005 | 10:48 PM
Quik's Avatar
Quik
foxes use a boot style connection and the sn95 uses a bolt up type flange......different
daltron
Apr 28, 2016 08:10 PM
Lethaldosage423
Oct 19, 2015 12:12 AM
Dokilar
15
Oct 16, 2015 08:13 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
1996cobraconvertible
SVT Forums
Sep 30, 2015 02:01 PM
