Code 33
Old Feb 21, 2010 | 11:16 AM
89stangbanga's Avatar
89stangbanga
Default Code 33
I ran my KOEO and KOER tests last night, and everything was clean except i got a code 33 saying that the egr valve was not opening correctly? What can i do to fix this besides replacing the part? Can i clean it out somehow? Any input is appreciated. Thanks
Old Feb 21, 2010 | 11:22 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
first determine if the valve operates properly, pull the vaccum line to it and manually apply vaccum with car running, if it kills the motor or runs really rough = valve fine, then i'd look into the evr selonoid operation which directs vaccum to valve
Old Feb 21, 2010 | 11:26 AM
89stangbanga
Originally Posted by mjr46
first determine if the valve operates properly, pull the vaccum line to it abd manually apply vaccum with car running, if it kills the motor or runs really rough = valve fine, then i'd look into the evr selonoid operation which directs vaccum to valve
Ok so run the car, pull the vacuum line, and if it runs and idles fine, that means that it is the valve correct? And if it dies, might be the solenoid or sensor plug?
Old Feb 21, 2010 | 11:30 AM
mjr46's Avatar
mjr46
no read my post........ pull line and using a vaccum pump apply vaccum manually to the valve, i use a vaccum pump cause it has a gauge and will indicate by leak down if valve diaphram is ruptured or not.
Old Feb 21, 2010 | 11:33 AM
89stangbanga
Oh ok i got you. Well don't have a vacuum pump but they can be bought fairly cheap right? I will look into everything, thanks for your help.
Old Feb 21, 2010 | 11:53 AM
mjr46's Avatar
mjr46
yup, sears sells "might vac" or autozone will have them for around 30 beans
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
