Question about a Vacuum booster for my brakes
I have a 1990 Mustang LX with a D.S.S. 357, it has a single plane intake and a Hi Lope cam combo, and it has the required vacuum booster kit with a elec. compressor installed. I bought the car with everything done already, now the brakes are getting harder and harder to press, I have been told two different things, the first being that the canister is bad, which is a quick fix and the second is that the vacuum pump is going bad, but the pump and the compressor sound the same as the day that I bought the car and the only difference is the the amount of pressure that I have to put on the pedal for the brakes to ingage. If somebody has had this problem before or knows the solution please let me know. Thanks
Usually on a stock vehicle, a sign of a bad brake booster is a very stiff pedal. Basically the booster is leaking internally. You could take alook at the booster check valve to see if that is working as it should or test the booster itself
mungodrums
Oct 7, 2015 04:01 AM
mungodrums
Suspension
Sep 7, 2015 07:22 PM
