heat sucks
ok so i drove the car to work today there are two heater lines one from the water pump top and one going to the intake bottom... the bottom one felt hotter like it burned me lol... the top one though felt very hot but not in a ouch kind of way.... hope that makes sense.... also while driving turned the temp **** to cold and the air got really cold and then went back to hot and the air got warmer all on low... tony how could i check this door do i have to take out the dash for this??
if clogged, try flushing first if not clogged either you have an air pocket induced into the system and if a recurrent issue = possible blown head gasket and if so not be the case, look into the blend door operation
wouldnt the car get hot and i would see coolant in the oil for a blown head gasket.....and when you say flush the system you mean drain all my coolant how do you flush the heater core... how do i check the blend door operation???
thank you for the help
nope not always, depends on where the blow is, if it happens around the firing ring that'll often allow compression/combustion gases into the cooling system......anyway to flush heater core , carefully remove the hoses going into the firewall and stick a garden hose in one side and watch until clean water and good flow come out the other tube
