fuel pump
Old Mar 4, 2010 | 08:49 PM
1989 stang's Avatar
1989 stang
Default fuel pump
hey everyone,
a new member here with a question on a fuel pump install on my 1989 5.0lx stang that stop working. i was wondering how hard is it to change and whats all the steps to go by when doing it. thanks for any info...
Old Mar 4, 2010 | 09:42 PM
AdderMk2's Avatar
AdderMk2
Banned
drain tank
drop tank
unclip fuel lines
remove fuel sending unit
replace pump
reverse order to re-install
Old Mar 4, 2010 | 10:56 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
^^^^^^that's about it
Old Mar 4, 2010 | 11:10 PM
raftdaddy's Avatar
raftdaddy
yeah it is that easy. start with taking the bolts out were you fill with gas the n move to the tank.the fuel filler neck just pushes into the tank.i then put a piece of wood under the tank and snugged up my floor jack under it. un bolted the two bolts on the top of the straps and took off the fuel lines.just watch for a little breather line on top of the tank .the ford fuel fitting are goofy with a white plastic inserts that lock on but the new fuel pump and new filters come with them.after it is out use a brass or aluminum punch and tap out the lockring(no sparks) and slip it out. make sure you de pressurize the fuel line and the fuel pump connecter is passenger side on the tank. but it is that easy.the hardest part is dealing with the gas in the tank
Old Mar 4, 2010 | 11:49 PM
ikeybmg's Avatar
ikeybmg
I suggest you go to advance and pick up a chilton or hayes repair manual. It will give you instructions with pictures. It's always good to have one if you work on your own rides. It's almost a neccesity.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
Sixx
Oct 5, 2015 07:36 PM
mrappe
Sep 26, 2015 10:16 AM
