over heating issues
Old Mar 5, 2010 | 10:37 PM
kane1983's Avatar
kane1983
Angry over heating issues
so blew a head gasket..... took the plenium off and valve cover off adn drained coolent...... let it sit for 5 months. rebuilt the motor and now it runs fine but it over heats. the wierd thing is it will be fine for a bit then the heater will blow cold air and then the car will get hot.... heater starts blowing hot air the car cool down. have already changed thermostat
Old Mar 5, 2010 | 10:52 PM
dreamer1uk's Avatar
dreamer1uk
Does the fan kick on when your idleing? Did you check to see if the heater core coolant lines are both warm?
Old Mar 5, 2010 | 11:10 PM
kane1983's Avatar
kane1983
has a mechcanical fan and it will work just fine go cold and get hot again.... and when it goes cold the car withh get close to over heating
Old Mar 6, 2010 | 04:56 AM
302army187's Avatar
302army187
is the fan working right?
did you put on the head gaskets correctly?
Old Mar 6, 2010 | 01:39 PM
mattdel's Avatar
mattdel
Air in the system.
Old Mar 6, 2010 | 09:23 PM
kane1983's Avatar
kane1983
the gasket is put on correct and i hvae bleed it numerous times..... im thinking water pump
Old Mar 7, 2010 | 09:03 AM
mattdel's Avatar
mattdel
The only way a water pump will cause the issues youve stated is if the impeller has come free from the shaft, which in itself is super rare, or the blades of the impeller have corroded/worn off, of which ive seen twice, after about 2000 water pump changes.
Old Mar 7, 2010 | 09:05 AM
mattdel's Avatar
mattdel
quickly fluctuating engine temp/heater temp is almost solely associated with air pockets trapped in the system.
Nick Oliver
Oct 17, 2018 04:22 AM
PaulH2
20
Jan 31, 2016 09:48 AM
chrisdbassplayer
Oct 13, 2015 06:53 PM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
