Gear ?
Old Jul 28, 2005 | 07:25 PM
Steed's Avatar
Steed
Default Gear ?
OK I got my 3.73 gears in the mail today started checking on how big a job this was and its to big for me so I started calling around for installation prices and from what im hearing I also need to replace the Outer Carrier
bearings both Pinion bearings a Crush sleave and a Pinion shaft seal did you guys replace these,would you recommend replacing these and if you got it installed how much they charge ya? thnx
Old Jul 28, 2005 | 07:29 PM
Quik's Avatar
Quik
Default RE: Gear ?
anything you do gears you should buy the install kit. this is all the bearings/shims you need.
install was 150 for me. plus my gears.bearings, girdle and fluids
Old Jul 28, 2005 | 07:31 PM
Steed's Avatar
Steed
Default RE: Gear ?
That doesnt sound that bad whod ya buy it from do you remember
Old Jul 28, 2005 | 07:48 PM
Quik's Avatar
Quik
Default RE: Gear ?
gears are FRPP got them from ford
girdle is TF got it from summit
bearings are Rachet [sp] got it from summit
friction modifier got it from ford
fluid PEPBOYS
and only a few hours for the install
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
