anyone running the trick flow diffenential cover
03-21-2010, 10:36 AM
if so how is the clearance with it? they seem a lot smaller then most...its about the same size as the ford racing one but a lot less expensive
03-21-2010, 10:52 AM
Banned
im running the larger Moser rear end girdle... clears my sway bar fine. The TFS should have no problems either
03-21-2010, 11:31 AM
I heard the clearance with most fox's is easy peasy lemon squezy
its when you get to the later years with the 8.8's its tight
. . . like adders 94
03-21-2010, 11:32 AM
actually where are you buying yours from im thinking about buying one too haha
03-21-2010, 02:34 PM
Quote:
Originally Posted by
Bobert
believe mine is the 8.8..
and buying it from here..cheapest i could find
http://www.cjponyparts.com/product.asp?pn=TFDC
03-21-2010, 03:48 PM
03-21-2010, 03:58 PM
03-21-2010, 04:23 PM
D.R. THE PATHETIC DORK
^^^^thanks
03-22-2010, 03:26 AM
i dont see the benefit other then easy draining and filling.
03-22-2010, 06:49 AM
the studs on the covers put light tension on the rear end main caps = keeps from blowing them out.
