engine break in?
Old Apr 14, 2010 | 10:07 PM
crob369420's Avatar
crob369420
Default engine break in?
On a fresh built 331 stroker. Do I need to use a break in oil? If not what weight? How should I do break in procedure?
Old Apr 14, 2010 | 10:17 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
10w 30 will be fine, I often use quaker state for such, to each his own.
Old Apr 14, 2010 | 10:23 PM
Bubba 95SN's Avatar
Bubba 95SN
10-30 Castrol warm up engine and make proper adjustments. Now make 10 20-60 mphr acellerations at wot. Let engine go back down to 20 mphr on zero throttle. After this flog the bitch as you see fit. Oh, almost forgot change oil and filte rafter the 10 cycle. Bubba
Old Apr 14, 2010 | 10:30 PM
crob369420's Avatar
crob369420
how bout sae 10w30 castrol gtx? What is wot?
Old Apr 15, 2010 | 07:03 AM
mjr46's Avatar
mjr46
will work fine^^^^^wot = wide open throttle
Old Apr 15, 2010 | 09:18 AM
luckythirteen13's Avatar
luckythirteen13
10w 30 is fine. be sure you beat the hell out of the motor to break it in
stanks347's Avatar
stanks347
My engine builder recomends using break-in oil with zinc in it. From what I understand the zinc coats the bearings and other parts and helps with longevity.
Old Apr 15, 2010 | 09:28 AM
Sxynerd's Avatar
Sxynerd
5w20 is what I use. You need an oil that's as thin as you can get it on cold starts so it has a higher viscosity to start with. The thinker the oil, the worse it is.
Nick Oliver
Oct 17, 2018 04:22 AM
aznpersuasion
Jul 11, 2018 06:40 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
Blk Vert
Sep 9, 2015 12:16 PM
