idles and runs rough--feels like missfire
I was driving my car and as soon as i put the air on it started to run rough, i turned the air off and it continued. The first thing I did was give it a tune up and clean the IAC but no fix, I disconnected the Battery for a couple of hours and started to runs smooth. I was driving it a few days later and turned the air on and Bam same thing, instant rough running.I cleaned the IAC again, disconnected the battery, set the TPS sensor and cleaned and opened the pins on the salt and pepper shakers---no luck.... Please help with any suggestions.
Dudeboy, I have some trouble codes
key on, engine off
key on, engine on
1st time
12--Idle Speed Control motor or Air Bypass not controlling idle properly (generally idle too low) - ISC
14--Ignition pickup (PIP) was erratic - Ignition Systems
19--Erratic idle during test (reset throttle & retest) - Idle Set Procedures
2nd time
3rd time
key on, engine off
key on, engine on
1st time
2nd time
3rd time
