Timing Problem
Old Apr 30, 2010 | 08:08 PM
30coupe1's Avatar
30coupe1
Default Timing Problem
I have a 89 5.0 supercharged. The car was tuned then blew a head gasket. After the head gasket was changed i didnt think that i had my timing right so i took the car back to the tuner because i thought the timing had to be set with the computer(i didnt know). So the tuner was trying to time it and said it wouldnt hold time. He thought it could be the ignition module, so i changed that and was trying to set the timing myself and when i go to 10 degrees the car runs like ****. Is the stock timing 10 atdc or btdc? I think the tuner marked the 10 to the right of the 0. If i go to that the car runs bad. When i go the other way it runs alot better but i know thats not right.
Please help
Old Apr 30, 2010 | 09:07 PM
g3mustang's Avatar
g3mustang
Are you checking timeing with the spout connector out??? Run codes to see what's going on
Old May 1, 2010 | 01:55 PM
30coupe1's Avatar
30coupe1
Yes the spout connector is out. Its on 10 now but when you bring up the rpms to about 4000 and let it back off it has a very slight rumble / backfire. What could that mean?
Old May 1, 2010 | 02:04 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
taking a shot in the dark here but, i would look at the timing chain or distributor.
djbigskrilla
Sep 20, 2022 01:04 AM
Cin K
Aug 31, 2015 07:31 AM
stormesixx
Aug 25, 2015 09:11 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
