gear install issues.
Old May 6, 2010 | 09:42 PM
ctgreddy's Avatar
ctgreddy
Default gear install issues.
Just put in some 4.10's in my buddies car. this is the 3rd set i've put in an 8.8 and the first set with issues. I used the ford tool for the pinion shim, and set backlash at .010. used some paint on the gears and the setup looked perfect. Installed them in the car, and it whines, loudly, only when there's torque to it. when you're off the throttle it's completely silent. also, when going over bumps it's quiet, even when in the gas a little. what could this be? the gears were used and they did have a couple knicks and chips, but i deburred all the sharp edges and figured it'd be ok. any ideas?
Old May 6, 2010 | 09:51 PM
AdderMk2's Avatar
AdderMk2
Banned
its likely because of the gears themselves
Old May 6, 2010 | 09:55 PM
ctgreddy's Avatar
ctgreddy
i've never had a problem like it before, would it cause any damage?
Old May 6, 2010 | 10:03 PM
Jfsram's Avatar
Jfsram
Check to see if the pinion nut didn't come loose.
Old May 6, 2010 | 11:55 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
problem with used gears is you need to set them back where they were originally set up, meaning on the same wear pattern, and if you didn't take them out of what ever they came out of, your throwing a blind dart, and if they were originally set up wrong, no matter where you set it it'll make noise
Granatelli Sales
Jan 20, 2020 12:34 AM
Nick Oliver
Oct 17, 2018 04:22 AM
musnicki
Sep 23, 2015 07:11 AM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 3, 2015 07:14 PM
