Idle issues?
Old Apr 13, 2010 | 05:57 PM
travixhouser217's Avatar
travixhouser217
Default Idle issues?
I got a 88 gt convertible. It sometimes drops rpms down to 500 when idling and then will pick it back up. sometimes it will drop so low that it dies. help please.
Old Apr 13, 2010 | 08:21 PM
smokedog's Avatar
smokedog
My 90 was doing this and the element in the MAF needed cleaning. Sprayed with brake cleaner and problem solved. Not sure though if the 88 is MAF or not.
Old Apr 13, 2010 | 08:52 PM
travixhouser217
It may be speed density. I hope its not
Old Apr 13, 2010 | 08:55 PM
86 5.0L's Avatar
86 5.0L
koeo/koer test and come back with the codes
Old Apr 13, 2010 | 09:07 PM
enix187's Avatar
enix187
Unless its a california car it's speed density, and nothing's wrong with that. To me it sounds like your Idle air control is going bad, and also it could be with the throttle position sensor. Take your idle air off and clean it, it's two bolts, spray into the little holes with carp cleaner then put a little wd 40 in it to lubricate and see if that helps.
Old Apr 13, 2010 | 09:17 PM
travixhouser217
where could i go to get that test run. the koeo/koer test? autozone?
Old Apr 14, 2010 | 12:17 AM
86 5.0L's Avatar
86 5.0L
$1 test light and a paper clip
http://sbftech.com/index.php?PHPSESS...ic,2471.0.html
Old Apr 17, 2010 | 12:53 AM
wadesquad's Avatar
wadesquad
id check for vacum leaks
Old May 6, 2010 | 11:27 PM
dannyroblez's Avatar
dannyroblez
Whats a KOER test? And how is it done? I hear it alot especially on the posts with "Idle" issues. Im having idle issues as well just like the guy that started the thread.
Old May 7, 2010 | 02:16 AM
86 5.0L's Avatar
86 5.0L
read the thread...
*hint* post #7
2007StangV6
Jan 28, 2016 06:09 PM
stangin1996gt
Sep 21, 2015 11:01 AM
LivingInThePast
Sep 16, 2015 12:20 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Emblazoned
Sep 3, 2015 10:45 PM
