ok so ive done some searching and found a quite a bit of stuff out about removing it but am a little confused in the exact things i need to just eliminate smog pump not egr at this time.
i know i either need an eliminator or shorter belt rerouted, other than that what do i need to do? thanks guys.
I turned mine into a idle pulley. took the back plate off took a hammer and chisel and knocked the impellers out of it. and now its just a idle pulley. also if anyone tries this make sure you dont damage the bearings and get all the graphit out of the two slots where the blades go though the slots.
