help with my dash pod clock
Lmao I have the same issue, oh also my cig. lighters don't work oh and my electric seat, These are all common though, Im pretty sure its your headlight/dimmer switch, Do this- Remove your cluster panel (dont know the name) than remove your headlight switch, look at the headlight switch connector that plugs into your headlight switch...... Let me guess, one of the wires that go into the back of the connector is melted and the connector itself is also melted around that one wire. Go do it than report back.
if you have mult items out(seat, dome light and other stuff) I would start in the fuse box.
Mine started working intermittenly when I found a deal on a remote radar detector that I mounted there instead, problems solved.........
no the dye should not have shorted things out. Pull out the radio and with the lights on, pull/tug/twist the wiring going to it and see if the lights come on/off which would signal a bad connection in the hrns.
not sure why your leaving your headlights on to test the battery and not really sure how long it should last but it does sound low. How old is the battery(although this probably has little to do with the lights).
Have you checked for power on the cig lighter? When you say you have checked all the fuses you included the fuses under the hood righ?
I am not purposely leaving them on for any reason. How I know the battery doesnt last very long is simple. The person who bought the car before me put the Halo Projector head lights on it. I hate them . Anyways I Had some issues with 1 headlight not working all the time. So I rewired them and removed the wiring fro the LED's anyways during this whole process that is how I learned the battery would die nearly after about 10 mins of being on but not running. The battery is 3-4 years old I believe from the date on it.
Yes I have checked all fuses in the fuse box under the dash and other the hood. Including 6 and 8 under the dash which are associated with the pod clock. I have not tried the cig lighter because I honestly I dont know if it worked prior to this problem.
I really was hoping that Kenne would be able to post his solution. Out of all the sites and posts I have read due to pod clocks not working and power seats not working. he is the only person to have listed all of my symptoms together and seems to have an idea of exactly what is wrong.
i'm having the same issue with my 95 gt. whenever i turn the lights on the pod clock looses power and doesn't keep time. it will blink one every once and a while but not for very long. i was thinking it may be a loose connection and from reading this i'm thinking i may be right. is there a fix for it like cutting out the harness and hard wiring everything??
