car wont stay running or idle cold
Old May 20, 2010 | 05:52 PM
dsmtamer2004's Avatar
dsmtamer2004
Angry car wont stay running or idle cold
I just bought an 88 gt and have a big issue. I just did a Mass air conversion but the problem was happening before then. when cold the car runs like ****, will not idle or accelerate and will pop and backfire till the car gets warm and then will run fine. so far i have put in 2 new o2's, ect, idle air motor, new computer, mass air flow sensor, fuel filter, adjusted the timing and nothing seems to be working. it runs rich as hell u can smell it upon start up. HELP????????
Old May 20, 2010 | 06:47 PM
mattdel's Avatar
mattdel
have you checked fuel pressure?
Old May 20, 2010 | 07:42 PM
g3mustang's Avatar
g3mustang
If fuel pressure checks out you try testing the tfi module... If you end up getting a new one make sure to get the right one for what tranny you have
Old May 22, 2010 | 05:59 PM
dsmtamer2004
yeah i have a brand new msd tfi on it. also fuel pressure is okay. wondering if i have a vacuum leak on the intake.
Old May 23, 2010 | 09:14 AM
suprakilla1425's Avatar
suprakilla1425
I've had the same problem with mine since I got it about a year ago. Same thing won't idle when cold, pops and runs rich as hell. I noticed that the previous owner broke a whole crap load of vacuum lines and attempted to repair them by putting a piece of rubber between the gaps. After replacing all of them with silicone tubing it has yet to stall out when it's cold. It does seem to reach idle before I think it should when it's cold, but it doesn't stall. I can drive it long before it warms up. I'd start replacing all the vacuum lines. It's cheap and 9 times out of 10 it'll fix the problem. The only difference between our cars is mines an 87 and still speed density.
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
89blueslug
Aug 10, 2015 07:20 AM
Jacob4589
Aug 8, 2015 11:00 AM
lrogers0613
Aug 6, 2015 10:51 PM
