Just a few minor EEC codes
Old May 27, 2010 | 07:12 PM
88foxbod's Avatar
88foxbod
Default Just a few minor EEC codes
22 - Map Signal out of range
31 - EVP Signal out of range
81 - Boost Control solenoid
84 - EGR vacuum Regulator
85 - 2.3L T/C Auto
I dont know why im getting the 81 and 85 since its a A9L computer out of a 90lx.
Other than that im pretty sure the codes are good because I deleted the EGR, Smog pump TAB/TAD, and the 2 vacuum cylinders in the passenger fenderwell as well as all those vacuum lines.
And I converted the 88 to Mass air so the Map port is open.
So agreed that everything is good? I just need to get a tune to delete the need for EVP, MAP, and EGR in the EEC?
Oh and I tried pulling codes with the engine running but when the test started it just about killed the car which stopped the computer. Whats up with that?
Old May 27, 2010 | 09:49 PM
AdderMk2's Avatar
AdderMk2
Banned
your map sensor should still be plugged into the harness, just not connected to a vac line.
Old May 27, 2010 | 10:01 PM
88foxbod's Avatar
88foxbod
Yup, it still is. The vacuum port is open.
Old May 27, 2010 | 11:28 PM
mattdel's Avatar
mattdel
81 is for the smog system, and 85 is the canister purge solenoid.
You can't eliminate MAP/BAP strategy from the computer. It's a needed input.
If you're getting a tune, work on getting 81, 84, and 85 sorted out of the strategy, then find out what's up with your BAP sensor.
Old May 28, 2010 | 10:16 AM
88foxbod's Avatar
88foxbod
Thanks matt. Ill look into it. Gonna pull out the shop manual and look at how to test the system.
Old May 28, 2010 | 10:36 AM
mattdel's Avatar
mattdel
I posted a diagnostic test in an image. if you're on a cellphone it won't show. access this thread from a PC and look at the image.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
firehorse02
Nov 16, 2015 11:28 AM
Urambo Tauro
Oct 5, 2015 09:37 PM
ChampInSD
Oct 2, 2015 04:55 AM
