Why bump timing
Old May 29, 2010 | 01:06 PM
89GTnoob's Avatar
89GTnoob
Default Why bump timing
Okay I read the tech article on how to, but it didn't explain why. If the truth is running higher octane gas doesn't improve power, then what makes timing make more power? I understand the basics of timing and how octane works, but I'm wondering how much power you can gain by taking it up a few degrees.
Old May 29, 2010 | 02:01 PM
luckythirteen13's Avatar
luckythirteen13
increasing timing starts the burn process sooner in the compression stroke creating more cylinder pressure and thus, more power. higher octane burns slower and resists detonation better allowing you to run more timing
Old May 29, 2010 | 03:51 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
in addition to more low end and mid ranger power you can gain MPG(if you can keep your foot out of it) and also cooler engine temps
Old May 29, 2010 | 04:43 PM
89GTnoob's Avatar
89GTnoob
Ah, thanks guys.
Old May 30, 2010 | 07:54 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
because its a proven fact that our cars make more power with more advanced timing (12-14*) even on 87 octane
Old May 30, 2010 | 08:10 PM
89GTnoob's Avatar
89GTnoob
I knew that it did make more power, just didn't understand how
Old May 30, 2010 | 09:47 PM
Bubba 95SN's Avatar
Bubba 95SN
Try retard timing, then drive car. After that experience you can appreciate advancing the timing...
Old May 31, 2010 | 05:03 PM
nitrous_bob's Avatar
nitrous_bob
because they work EXACTLY opposite
you add octane for a lean condition... but yet you want to be lean as you can SAFELY be for optimum power. more octane or less timing makes u safer
octane reduces combustability chemically, so it retards detonation, just like less timing does mechanically
get it now ???? if not.... i'll explain as best as i can
Old Jun 1, 2010 | 09:34 AM
89GTnoob's Avatar
89GTnoob
I understood what everyone else said, but when you brought air/fuel ratio into this, it went over my head. If you have a lean condition, you'd want to add more fuel, not higher octane...... ?
Old Jun 1, 2010 | 11:57 AM
redemption's Avatar
redemption
+1 on what lucky said
