Wheel alignment
Its been 3 months that i have gotten my wheels aligned. The passenger's side tire has even wear. On the Driver's side the outer side of the tire is worn so bad, its about to blow. I've taken it to the alignment shop again and he said everything is within spec. My car is not lowered and it doesn't have any suspension modifications. Is there something else that could be causing this?
i believe so, my car doesnt have camber/caster adjuster plates so they can only align it so good, unfortunetly my right side is bent so it wears terribly on the right side of the tire. ive just ignored it until i can get maximum motorsports adjustment plates, well until i can afford it. =] hope this helps
Thanks guy. I took it a small shop because they are usually more better than the bigger ones IMO. But the guy even hooked up to his machine and showed me. He mention my tire pressure was low. But it still keeps getting worn after it being inflated to spec. I'll take it to another shop and see what they say.
Post your alignment numbers. I don't believe it's a lack of caster/camber plates.
These cars have about -0.5 camber and lowered Mustangs have -2 to -3.0 deg camber. That will wear the inside edge of a tire. To wear the outside edge one ONE SIDE ONLY.
There is major problems somewhere in the front end. It may look ok and align ok sitting on the machine but a worn suspension may allow it to move to a different spot while driving or braking.
if something is bent, expecially where it is wearing the tire....it will and I repeat will show up on the alignment machine
