Rear control arms.
Old Jun 5, 2010 | 03:49 AM
Jfsram's Avatar
Jfsram
Default Rear control arms.
Are the stock upper and lower rear control arms from a 94 V6 Mustang the same as a 93 5L LX?
Old Jun 5, 2010 | 05:02 AM
AdderMk2's Avatar
AdderMk2
Banned
more or less. there might be a slight diffrence in the bushing material. but nothing performance note-worthy
Old Jun 5, 2010 | 08:21 AM
Jfsram's Avatar
Jfsram
Bushing material, not a problem. I'll be throwing fresh bushings in them anyways.
As long as they are dimensionally the same then I can grab a stock set from a 94 parts car, that's all they're good for anyways. LOL
I was pretty sure, since most of the aftermarket arms list the application range from 79-98. Hate to find out there is a difference after I install new rubber bushings, sandblast and paint them. Thanks.
Old Jun 5, 2010 | 09:08 AM
ctgreddy's Avatar
ctgreddy
why are you putting all that work in stock control arms?
Old Jun 5, 2010 | 02:51 PM
87Stallion's Avatar
87Stallion
You can buy a set of tubulars cheap these days.
Old Jun 5, 2010 | 03:35 PM
91stang02's Avatar
91stang02
87stallion i need ur help ive seen your other foxbody the one with the saleen wheels and i was wondering if u could help with tire sizes?
Old Jun 5, 2010 | 09:09 PM
Jfsram's Avatar
Jfsram
I'm going back to stock rubber mounted arms because I feel that alot of these arms are hard on the frame for street driven cars.
There are the heim jointed arms that allow articulation but my South Side Machine arms have a solid bushing and do not. The in between comprimise would the any polyurethane control arm but I think they are just a comprimise between solid and rubber. Still rough on the frame when articulating.
I understand these are basically just sheet metal stamped arms but on a 13 second car, why do you all feel the importance of aftermarket arms?
Old Jun 6, 2010 | 05:06 AM
AdderMk2's Avatar
AdderMk2
Banned
get the torque box reinforcement kit and keep the southsides
Old Jun 7, 2010 | 03:55 PM
Jfsram's Avatar
Jfsram
The reinforcement kit is on order.
As for keeping the South Side. **** no. Did you read the part about NO ARTICULATION.
Reinforce the frame all you want. There is no articulation in a solid bushing rear control arm. There is not much on a polyurethane bushed arm either.
FivePointToTheOh
Sep 14, 2015 03:35 PM
Dragonus18
Sep 9, 2015 01:21 AM
Sep 8, 2015 11:50 AM
M3hunter
Sep 5, 2015 03:42 PM
