charging problem
I have a 92 GT 5.0
it had a dead battery so I bought a new one. then the battery wasn't recharging so I took my alt. to advance auto and they said I need a new one so I bought one of those too. now its still not charging. I purchased new connectors and will install them on Monday, but does anyone know anything I should check? Thank you
Also check all of your fuses. Pull the d plug off the alt (the regulator plug) and make sure that you are getting the 12 volts from the light green/red wire. If its not sending its 12 volts it will not charge either. The power comes from your instrument cluster to the alt just for your reference.
The wire runs underneath the batt. tray so I pulled the batt. and tray and I still cant find the fusible link. I even purchased a haynes repair manual for extra help. I assume the link would be extra covered due to the underhood heat, but I dont wanna split the entire wire open if I dont need to
