help with ECC codes
Old Jul 5, 2010 | 06:44 PM
AW11SC's Avatar
AW11SC
Default help with ECC codes
hello all
i'm new and need to keep this short!
I did a can on my buddy's 91 GT
came up codes 40-12-91
the 12-91
which i guessing is just part of the scan trying again
i know 91 is dead 02 but which one?
12 its idle controller motor acting up?
but whats code 40?
Old Jul 6, 2010 | 07:30 AM
AW11SC's Avatar
AW11SC
any thing?
Old Jul 6, 2010 | 11:13 AM
pelley's Avatar
pelley
actually the codes repeat, as double assurance that you wrote the numbers down correctly.
here's the codes as follows
"12- system cannot raise engine speed above normal idle"
"91-exhaust gas oxygen (ego) sensor - signal voltage always indicates "lean" either during engine run self-test ("rich" air/fuel conditions) or normal engine operating conditions. OR transaxle problem - shift solenoid 1 (ss1) circuit failure.
alright man thats how it is straight from the book, and as i can see here theres no code "40" cause a code scanner cant beep a zero...
try the codes again if its just a "4" it basically means the self-test is starting..
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
