exhaust studs?
exhaust studs?
im having trouble with my stock header bolts, primaries on my shorties are in the way. it would make it easier if i had studs, my question is, can i just go to autozone and get these
http://www.autozone.com/autozone/acc...er=426025_0_0_
even though it says 90-06 ford and i drive a 87 5.0 gt?
will they fit fine?
will they fit fine?
I took a torch to the studs on the collector, removed the studs, then drilled out the hole a little. Now I use some bolts/washers/lock washers/nuts. It was a quick fix and cost effective but probally not the most convienent considering I need a wrench up top now to keep the bolt from spinning while tightning the nut....
Get some header bolts from Summit or wherever. They have a smaller head, usually 3/8". I don't like 12 point heads for this application. You can only use a box wrench. Often there isn't enough room for a box wrench.
SOmetimes the bolts are too long, and hit the header tube if it's curving in that direction. If you tighten down all the bolts, you'll find that bolts hits the header tube and you can't tighten it. If that's the case, start by screwing them in only half way. Then go back and tighten them the rest of the way.
I use split lock washers, and I never have trouble with them coming loose; I don't know why, as so many people do. But you might consider one of the mechanical locking devices.
