EGR Issues w/ Codes
Old Aug 7, 2010 | 12:54 PM
94Blk5.0's Avatar
94Blk5.0
Default EGR Issues w/ Codes
Code 332 "Insufficient EGR flow detected" had prompted me to remove the EGR to make sure the passages were clear. I replaced the vacuum lines coming off the intake manifold going to the rubber junction, and the line going from the rubber junction to the EGR. Also, if I apply vacuum to the EGR with my lungs the idle will dip slightly then return to normal. I thought that the idle should be effected more than that...No?
Now I have KOEO codes 332 and 334"EGR close valve voltage high."
Any advice would be greatly appreciated.
Old Aug 7, 2010 | 01:52 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
YOU WON'T BE ABLE TO PULL ENOUGH VACCUM THROUGH your lungs all the way through the small vaccum line, tried it many a time, use a vaccum pump, anyway, you need to test the evr selonoid to see if it is opening when commanded by the ecm, simply put a tee into the vaccum line to egr valve , run the koer and during the egr portion of the koer test you should briefly see a significant rise and then quick drop on the vaccum gauge when egr is on then off, or simply remove the evr selonoid and apply 12v and a ground to it and see if it clicks and the port switched from closed to open
Old Aug 7, 2010 | 03:27 PM
94Blk5.0's Avatar
94Blk5.0
^ Thanks, mjr.
Where could I find the EVR? Following the vacuum lines from the rubber junction, they seem to go into the fender on the passenger side.
Old Aug 7, 2010 | 08:34 PM
Bubba 95SN's Avatar
Bubba 95SN
Inside passenger fender.
Old Aug 8, 2010 | 03:26 PM
94Blk5.0's Avatar
94Blk5.0
No luck...
Old Aug 8, 2010 | 04:50 PM
mjr46's Avatar
mjr46
in what way no luck?? what tests did you do??
Old Aug 8, 2010 | 05:09 PM
94Blk5.0's Avatar
94Blk5.0
^ Sorry for the lack of clarity. I had no luck locating the EVR.
Also, if I apply vacuum to the EGR directly from the intake manifold at idle, it runs rough. So at this point, I have a bad EVR or a vacuum issue between the rubber junction and the EVR?
Old Aug 8, 2010 | 05:40 PM
Bubba 95SN's Avatar
Bubba 95SN
As stated earlier in this thread...the EVR is inside inner fender on passenger side.(remove black plastic cover inside fender) Follow the hoses. Ther should be a cap that is removable on EVR that has small foam filter. Cleaning it can sometimes make it work.
Old Aug 8, 2010 | 07:01 PM
94Blk5.0's Avatar
94Blk5.0
I appreciate the help. Are you talking about removing the wheel well liner?
Old Aug 8, 2010 | 07:18 PM
mjr46's Avatar
mjr46
yes , he is........test is while in there as I stated
