93 gt speedo problem
Old 08-14-2010, 08:27 PM
chilywily72
chilywily72's Avatar
Default 93 gt speedo problem
So im rebuilding the t5 in my tranny and im almost done but i want to fix my peedo problem i only drove my car for about 10 minutes home after buying it and noticed that the speedo climbs really fast and when id say id be doing around 55 60 the speedo says like 85 90 what would cause this? My tranny speedo gears dont look that bad would it be a cable or a sender possibly?
chilywily72 is offline
Old 08-14-2010, 08:41 PM
93hatch306
93hatch306's Avatar
What gears are in the rear axle and what color gear is on the speedo cable? Sounds like it has the wrong speedo gear.
93hatch306 is offline
Old 08-14-2010, 09:09 PM
chilywily72
both gears are yellow not sure as to the gears in the rear end i think im gonna have to do the whole marking the driveshaft and turning a tire to figure out whats in it
Old 08-14-2010, 11:20 PM
93hatch306
93hatch306's Avatar
yellow is the 18 tooth gear, used on 83-89 cars with 3.08 rear gears.
Old 08-15-2010, 10:46 AM
nitrous_bob
nitrous_bob's Avatar
is the trans still apart ? you should put a black 6 tooth drive gear in it while you have it apart. then you can correct for all the good gears with a smaller 17-20 tooth driven gear. '93 used a 8t drive just like the aod's so you can only really correct to 3.27's with a 21t. the 23t is NOT a ford gear and WILL chew up after a period of time
but yeah it's the gearing for sure.... you prob have 3.73 or 4.10 and the car originally had 2.73 with the yellow gear
door tag shows original gearing... under "ax" m=2.73 , z= 3.08 , e= 3.27 but 3.27 was only available in aod's
with a black 6t, you want the same yellow 18t for 3.73 or a black 20t for 4.10's
nitrous_bob is offline
Old 08-15-2010, 11:34 AM
chilywily72
Ok well down the road i plan on putting 4.10's in it so i should put in the tranny a black 6th gear and keep my yellow gear on the speedo sender?
Seanam
10-04-2015 10:15 AM
mdj89
09-23-2015 08:49 AM
kachuy10
09-22-2015 01:27 PM
stangin1996gt
09-21-2015 11:01 AM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
Quick Reply: 93 gt speedo problem
