few questions about 94 aode trans
hi i found an aode trans in a 92 5.0 but if im not mistake. the fox body mustang have aod trans. so how can i tell these two trans mission apart. a physical description would help alot . thanks
An aod will have a mechanical linkage attatchment on the gear selector arm and the aode will not! the pans are identical i believe so you cant just look under the car! the 92 dosent have an aode unless someone went thru some trouble putting it there!
Daddys Girls GTs
09-14-2015 08:46 PM
