problems up the a$$
Old Sep 13, 2010 | 05:39 AM
GTnotchback's Avatar
GTnotchback
Default problems up the a$$
ill try to make a long atory short. Got a chip burnt for my computer. Realized the 02 sensors were both broken so i replaced them. Moved timing down to 14 deg. and put the pill back in. Placed the chip in the computer and the car ran like a raped ape at first then started running super rich. Hooked it to the laptop and 02 sensor were not working. Found broken wire hooked it up and fries the computer. Ended up having the orange wire ground behind the intake not grounded.(wasnt hooked up) So i hooked it up an bought another computer. Got it home and realize i bought a junk computer. (thanks dam guy). Got another computer and i check it in the other stang and it fires right up so i know i have a good computer now. So i put it in my car and my car will not start now at all. It almost acts like it wants to fire a little but nothing happens. Looks like im not getting spark. On the laptop it shows the tps,o2sensors, and everything are all out of wack and not funtioning. im assuming i have some kind of electrical problem. I tried a different injector harness and it didnt change nothing and also went through the computer harness and found no problems. Any ideas? Im getting really fed up with this junk. could it be my distributor tfi module? open to any suggestions?
Old Sep 13, 2010 | 05:45 AM
GTnotchback
i also forgot to mention that i tried another coil and it didnt help.
Old Sep 13, 2010 | 08:18 AM
GTnotchback
anyone have a suggestion/idea???
Old Sep 13, 2010 | 08:57 AM
Sidewayz6.0's Avatar
Sidewayz6.0
The easy solution is to pull all your EFI **** off, and put a carb on it.
I chased issues like this for awhile, and just bought a new harness. The original one that was in my car was hacked up and spliced everywhere. However, even after all that, it still won't run the fuel pump. So I just have a hotwire kit on it.
Old Sep 13, 2010 | 10:14 AM
GTnotchback
ya i know this but i would really like to keep my fuel injection. carb is a last resort. ill try a new tfi tonight but after that i dont know what else to try. thanks for the reply
Old Sep 13, 2010 | 10:37 AM
enix187's Avatar
enix187
fuse links, start checking them
Old Sep 13, 2010 | 10:44 AM
GTnotchback
where at and how do i check them?
Old Sep 14, 2010 | 05:13 AM
GTnotchback
it was the tfi module. the car start good now but just runs super rich for some reason.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
