Annoying Audio Whine
I'm not sure if this is an easy fix or appropriate for this section but i recently got a sub, amp, and head unit installed in my 93 GT and there is alot of audio whine. Does anyone kno why that would be or how to fix it?
RFI, radioshck or any other eletronic supply store will carry a noise filter that will make it go away!
That is a very annoying sound indeed lol! mine use to be in sync with the rpms sure yours is too! usually cones from the ignition system!
Before you spend any coin replacing parts or buying filters, make sure you have a DAMN GOOD ground for your amp. Putting the grounding lug onto painted bodywork with a sheet metal screw through it is not enough. Sand a clear spot through the paint, screw the ground lug down and if in doubt, add another grounding lug to another point in the body.
Just my $.02 but I've seen (heard) it happen more than once.
thanks for the replies guys i did end up figuring it out..there were so many wires running in the same spot and it seems it wasnt grounded enough..best buy "ground loop" 15 bucks runs right into rca's in amp..no more whine
JoshyGT
The New S550 2015-2020 Mustang
16
09-19-2017 09:52 PM
