Supercharger?
Supercharger?
I have been looking at different superchargers. I was considering the vortech and running about 8 lbs of boost. I have heard that i will have nothing but problems if i put one on. My car with the mods it has runs great. Will I get oil leaks from 8lbs of boost? My heads are not o-ring grooved. I like going fast but i also like reliability.
RE: Supercharger?
you should be fine with 8psi as long as you have around 9ish:1 CR
blowers are nice but remember what it takes to gain 100hp isnt as easy as what it takes for juice to make 100. and a juice motor is more reliable since its not always being abused by higher CR ratios where boost will create higher CRs. now for a strip car juice is better but if you want all around power then yes the blower is nice...and sure sounds pimp
RE: Supercharger?
you should be ok with 8psi and the DSS shortblock, what heads are you running?? why do you think a blower will cause oil leaks?? it will cause a blown head gasket, but i havent ever seen one cause an oil leak, except regular seapage from the feed lines.
RE: Supercharger?
I was considering runnin nos, (its alot cheaper) but I dont know enough about it. I dont want to blow my brand new motor. I pulled 312hp at the wheels and the motor only has 150 miles on it. My wife would freak if I blew it up runnin nos.
RE: Supercharger?
if the car is for the 1320 then nothing wrong with the spray. you can spray a motor for about 40second consistant but i personally wouldnt do that. within the time it be more then enough to Walk a few things
ORIGINAL: 91stang
i wouldn't like it having to fill up the tanks. and i'd rather have continuous hp than 1 quick shot. but that's just me.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
