Cam help
Old Jan 26, 2011 | 09:32 PM
94Yellow50's Avatar
94Yellow50
Default Cam help
hey all, been a while since I have been on here. but been busy also. anyway finally pulled the motor out before winter, and been buying parts over the cold snow months to put a motor together for spring. gettin down to final parts and main piece missing is the cam. its gonna just be standard 302/306 after machine work. forged pistons from dss for trickflow heads. the heads are the 170s with the upgraded spring package. part number
TFS-51400004. anyway. since i have a 94 with a more picky computer, i was considering the steeda 19. its been quite a while tho since ive looked much into cams, so maybe ive missed something better thats come out. i know best bet would be the custom route, but just seeing if there is an ots cam that would suit me well. not lookin for all strip use, but will start seeing more than it has. needs to be able to drive without to much idle issues. basically its a gonna be a hci 306 with a 5spd and 3.73 gear. any imput on the matter is much appreciated since this and some minor gaskets/fasteners are the final parts for the build. thanks guys
Old Jan 26, 2011 | 09:37 PM
Venomantidote95's Avatar
Venomantidote95
Sure there are plenty of ots cam that would more than suffice. What intake?
Old Jan 26, 2011 | 09:44 PM
94Yellow50's Avatar
94Yellow50
my bad, forgot the intake. stickin with the gt40 intake i have on there for now.
Old Jan 26, 2011 | 10:28 PM
Venomantidote95
The stage 1 or 2 trickflow cam will work well with those heads.
Old Jan 26, 2011 | 11:06 PM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
Steeda 19 with 1.7's
Old Jan 26, 2011 | 11:10 PM
frdmstng1986GT's Avatar
frdmstng1986GT
+1. Its a good cam that is designed to work with 94+5 ecm's. The trickflow ones are good too but might give you some idle issues.
Old Jan 26, 2011 | 11:18 PM
Venomantidote95
I must be oblivous to this idle issue with the more forgiving ecms in our sn cars! Idk maybe ive just been lucky, used an e cam, 2 comp nitrous cams, xfi and stage 2 tfs not the first idle issue!
Old Jan 27, 2011 | 04:26 PM
94Yellow50's Avatar
94Yellow50
lol how bout with 1.6s? already bought those, guess wouldnt be too hard to exchange, but still perform as well with the 1.6's?
Old Jan 27, 2011 | 05:22 PM
sn95_331_GT_ yellow
yeah itll be fine, but .510" lift is better than .480" and the 1.7's give a little more area under the curve
you could always retard the 19 by 4* and have a little bit of fun with the 1.6;s too
GimpyHSHS
19
Dec 19, 2023 01:12 PM
patchshaffer
Tuner Central
Oct 5, 2015 02:24 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
Ryan Fitzpatrick
Sep 14, 2015 02:21 AM
