annoying vibration on freeway...please help
When im going 55mph it starts to vibrate near the dash area and around 70mph it gets worse. Once I let off the gas, the vibration is gone. If i slowy give it gas and stay under 40mph, I don't notice it.
Ive checked the U joints, replaced spark plugs, fuel filter and checked the cap/rotor & wires. It also idles perfect and doesn't miss, studder or anything. Also, fuel pressure is at 43.
Any ideas, this is really getting annoying? It started doing this 4 days before I got new/wheels tires.
No, i doen't vibrate around the shifter. The vibration is coming from around the dash. I thinking it may be the balacer, but I replace that a couple of years ago and it made the shifter vibrate alot. Im gonna take another look at the balancer.
Vibration under a load could a lot of things. Start by checking the simple stuff: timing, fuel pressure, clutch adjustment. Put a thermometer on each header tube and make sure they're all about equal.
You said you changed the balance a couple years ago; what did you use as a replacement? You might want to check that again.
Have you made any motor changes lately?
I replaced the balancer with a ford repalcement about 20k ago. It has no cracks in the rubber and doesn't budge when trying to twist it. I replaced the tranny mount with a urethane and stock ford motor mounts around the same time. I checked to make sure they're not cracked and the nuts are tight.
I ran KOEO/KOER again yesterday and came up with nothing. I did notice that if I rev it to around 4K, I doesn't shake at all and doesn't cut out or anything. Even when i go WOT, I notice NO power loss.
Adder mentioned the differential fluid, I should probably check/replace that. Bob., I did check the fuel pressure. Its at 43, vac line off and 32 with vac line on. Im staring to think i has to be the U joints, but i didn't feel any play in them.
I did have a Code 31 a couple weeks ago for low voltage at EGR. Could a bad egr cause these symptoms?
Thanks guys, I appreciate it!
