Hurst roll control issues brakes locked
So I just installed a hurst roll control ran all the lines and wired it up, bleed the brakes. Now without even activating the roll control the brakes lock and will not release. Double checked the hard lines and everything seems good. I turn the car on and hit the brakes without activating anything and they stay locked so I turn it off and the brakes release so i assume its electrical.
I have the solenoid grounded and ran a line into the car with the supplied fuse spliced in. Then ran the led to the black wire on the switch and grounded the led. Then ran the power wire and red wire on the switch to a switch 12v on the fuse block. Any input would be greatly appreciated. thank you
Sounds like your switch might be screwed and constantly closed. You can check the wire after the switch that feeds voltage to the solenoid. If there is voltge after the switch without pressing it the your switch is screwed.
Do they work normally without the fuse installed? Sounds like its wired right.
Faolan65
08-27-2015 06:40 AM
