TPS low voltage
Old Apr 27, 2011 | 07:27 PM
smythge's Avatar
smythge
Default TPS low voltage
I'm having bad surging idle issue on my 94 Cobra. I have an adjustable TPS I was getting a .33v reading at closed throttle, at WOT I am getting a 2.50v I've adjusted it all the way and the most I can get is .58v and WOT 2.75v I am looking for a confirmation that this is a bad sensor, or is there something else I should be checking? Any help is appreciated.
Old Apr 28, 2011 | 12:22 AM
nitrous_bob's Avatar
nitrous_bob
are you checking voltage with key on but engine not running ????
Old Apr 28, 2011 | 03:16 AM
AdderMk2's Avatar
AdderMk2
Banned
You need to check the VREF voltage and make sure you are getting a full 5v TO the tps. If you are... replace the sensor.
Old Apr 28, 2011 | 06:48 AM
smythge's Avatar
smythge
Yes key on engine off and I checked the VREF voltage (brown wire) and it is 5 volts to the TPS
Old Apr 29, 2011 | 08:10 PM
IRoman's Avatar
IRoman
You do that when the car is running right? (Im having the same problem)
Old Apr 30, 2011 | 01:00 AM
AdderMk2's Avatar
AdderMk2
Banned
If you cant get full voltage across the range of the TPS, but have a good TPS VREF. You need to check its ground, and replace the sensor.
no. KOEO, not KOER
jwog666
Dec 27, 2021 08:09 PM
CS2007
Jun 25, 2019 09:45 PM
TCStangerv6
Oct 11, 2015 05:57 PM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
