Coolant backing up into overflow res
Old May 3, 2011 | 03:57 PM
brandon murray's Avatar
brandon murray
Default Coolant backing up into overflow res
1991 5.0 mustang gt
coolant backing up into reservoir not returning into radiator overflowing
leaving radiator empty
Old May 3, 2011 | 04:48 PM
67mustang302's Avatar
67mustang302
Sounds like a bad radiator cap.
Old May 3, 2011 | 05:19 PM
brandon murray
thanks 67mustang302 i bought new cap. will try on way home from work
and let you know.
Old May 3, 2011 | 08:00 PM
brandon murray
Default coolant still backing up into reservoir starting to over heat
tried new cap. still doing same thing
Old May 3, 2011 | 08:56 PM
jwog666's Avatar
jwog666
check to make sure that the hose that runs from the radiator to the resevoir is secured properly at both ends, if its loose it can suck air instead of coolant when the motor cools down. if that checks ok check for pressure while running, its possible to have a bad head gasket push all the coolant out.
Old May 3, 2011 | 10:27 PM
thunderjet429's Avatar
thunderjet429
Sounds like a head gasket to me, a block test needs to be run.
Old May 4, 2011 | 12:48 PM
brandon murray
Default blown head maybe?
ill do a block test. i was thinking head gasket also but there is no other
signs of blown head. still runs strong, no water in the oil and no water coming out of exhaust. what about a pluged radiator? when i try to burp the coolant system thermostat opens and coolant is pushed out of radiator?
Old May 4, 2011 | 01:06 PM
67mustang302
Does it run fine when warmed up, but after you shut it off the coolant doesn't go back into the radiator? Or is it filling the overflow and spilling out when the car is running?
Old May 4, 2011 | 02:02 PM
brandon murray
Default while its running
it overflows when its running. when you shut it off and let it cool it sucks
back some coolant but not all. leaving radiator low and overflow bottle too
full.
Old May 4, 2011 | 08:42 PM
brandon murray
Default new problem
found coolant leak behind water pump. could this cause the overflow problem?
