Unknown problems
Old Jul 4, 2011 | 11:20 PM
crossds's Avatar
crossds
Unhappy Unknown problems
I am experiencing problems that feel like my TPS is going bad. I just replaced the TPS, only to find out that it wasn't the problem. The car sputters at acceleration, and dies routinely. Can someone please help get this pony up before I give into it?
Old Jul 4, 2011 | 11:40 PM
AdderMk2's Avatar
AdderMk2
Banned
need more info... hows about you start with...
What do you drive? What mods does it have? How long has it been happening?
Old Jul 4, 2011 | 11:43 PM
TexasTanker19kilo20's Avatar
TexasTanker19kilo20
Goldilocks
+1 Adder, oh and welcome to MF. Need details.
Old Jul 5, 2011 | 10:14 AM
crossds's Avatar
crossds
I don't have any mods on it and it has been doing it for about a week. It also backfires, which leads me to believe that it is an ignition problem. It only has the problem when it is cold too. After the engine gets warm, then no problem.
Old Jul 5, 2011 | 10:15 AM
crossds's Avatar
crossds
BTW, I drive a 90 Mustang 5.0
Old Jul 6, 2011 | 02:57 PM
Super88's Avatar
Super88
Fuel injectors maybe? try running some STP fuel system cleaner in the tank next time you fill up. Its on like $4. or some sea foam if you prefer, that stuff works wonders. Spark plugs is a possibility too. When was the last time those were checked or changed?
Old Jul 6, 2011 | 07:04 PM
MustangBradley's Avatar
MustangBradley
Often, the first step in diagnosis is to pull codes from the computer. If you had done that first, you would probably not have seen the TPS in the fault list, thus saving you the cost of that part. The moral of the story is don't replace parts without evidence that the part in question is at fault.
Sometimes, the codes will tell you what the problem is NOT so you can focus on other things.
Do a search on pulling codes and report back your findings.
Good luck.
Look at this as a learning opportunity. More knowledge is always better.
Old Jul 6, 2011 | 09:59 PM
wydopnthrtl's Avatar
wydopnthrtl
A typical issue with these 5.0L engines is a dirty MAF. Clean the (exposed) wires with the special spray.
My 2nd guess would be a bad crank position sensor.
Old Jul 7, 2011 | 11:24 AM
AdderMk2's Avatar
AdderMk2
Banned
I'm pretty sure this is the second time you have suggested a crank position sensor...
302's IN FOXBODIES AND SN95's DONT HAVE A CRANK POSITION SENSOR... STOP SUGGESTING IT!!!!!
Old Jul 7, 2011 | 09:54 PM
wydopnthrtl
LOL... your right. Man I'm just not in tune with these old school engines yet.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
