Help with setting timing
Got a 1988 LX, look at my sig for mods. It seems to hesitate a little when i romp on it, get an occasional backfire, sorta sounds like timing to me. I havent had a chance to work on it yet and honestly i dont know how. My question is how can i adjust the timing so it wont hesitate and what not. I have limited access to tools because im station overseas so the simplest method would be best.
thanks
thanks
I'm only familiar with Holley & Q jet carbs. And its been a long time since I've messed with them.
Seems like I recall a hesitation on tip in was almost always too small an accel shot. Too much accel pump would not likely stumble. Just feel a bit soft and not as powerful. Same holds true for EFI tuning.
And the backfire would be a combo of fuel, timing, and cam overlap.
I'd first try adding fuel for tip in (I assume you have a mechanical accel pump that can be adjusted)
This is a excellent cause for getting a wideband or borrowing one. It makes this kind of tweaking 10 times easier.
Regards,
Rich
Regards,
Rich
