Ball Joint MESS
Old 09-04-2011, 05:49 PM
cholericfc
cholericfc's Avatar
Default Ball Joint MESS
I have an air hammer with pickle forks and can't remove my spindle/steering knuckle from the car. I've strained my arm trying to beat the pickle fork extension with a hammer. I have a huge gash on my hand.
How do I get this thing off. I guess maybe I need a stronger air hammer?
cholericfc is offline
Old 09-04-2011, 06:22 PM
mustangGT86_05
mustangGT86_05's Avatar
Are you just trying to push the pickle fork inward? Some times you gotta take a bfh and hit them downward too, this helps pry them apart
mustangGT86_05 is offline
Old 09-04-2011, 07:32 PM
cholericfc
cholericfc's Avatar
Yup. Doesn't work. Only thing I haven't done is use a sledge hammer.
I have a new spindle and new ball joint for the car = USE A GRINDING WHEEL AND CUT IT ALL OFF?
Old 09-04-2011, 07:41 PM
tohoopty
tohoopty's Avatar
well use a sledge hammer then and dont hit like a girl
tohoopty is offline
Old 09-04-2011, 07:47 PM
67mustang302
67mustang302's Avatar
Don't use pickle forks, they suck.
Go get a real ball joint remover. Napa and others have one that looks like a big fat pair of blunt scissors(sort of) with a fork on one side and an arm on the other with a big *** bolt in it. Slip it on and tighten the bolt to pry the arms apart and separate the ball joint. That's what I use, just tighten it up really good and give it one or 2 good whacks with a hammer and they pop right out.
Pickle forks rarely work, and never work well(unless the joint is already loose).
67mustang302 is offline
Old 09-05-2011, 01:02 AM
cholericfc
cholericfc's Avatar
I currently trying to separate the steering knuckle/spindle from the ball joint.
Old 09-05-2011, 01:09 AM
mustangGT86_05
I dont know what kinda pickle forks you use, but they always work for me. You just need a BFH to go along with them. You can always get a jaw puller but those can be a little tricky
Old 09-05-2011, 07:47 AM
cholericfc
cholericfc's Avatar
I don't want to bend/hurt anything like my control arm or K-member....
Old 09-05-2011, 08:50 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
If you are talking about the TIE ROD END (steering knuckle)..... make sure your steering wheel is straight, soak it in penetrating oil, and heat the spindle up. Find a nut that fits the tie rod end and thread it on almost all the way and beat that part with the hammer. Using the right tools as said above does make things alot easier though.
projectresto83 is offline
Old 09-05-2011, 12:49 PM
cholericfc
cholericfc's Avatar
I did use those tools. I ended up getting it off with an angle grinder to the spindle...
Now, I have a ball joint press... I have 94' ball joints but I don't know how to use the press.... If I can do this I'll be able to finish my car finally
Quick Reply: Ball Joint MESS
