AT a lose, need some help.
Old 11-18-2011, 10:31 PM
soulfried
soulfried's Avatar
Default AT a lose, need some help.
To begin with, my pony blew the gasket on the water pump. After replacing it and reconnecting the battery it wouldn't start. I put a trickle charger on it, after an hour or so the needle kept jumping from charged to half charge. I exchanged the battery for a new one, installed it, and it still wont start. The starter is only a year old and has never hesitated. What throws me off is my brake lights wont go on when hitting the pedal, but blink when using the alarm. Power to everything else is fine. I'm thinking maybe the alarm got messed up when the water sprayed and possibly got locked in a kill switch mode. Any ever have a similar problem or have any ideas as where to begin? Appreciate any advice.
soulfried is offline
Old 11-19-2011, 06:54 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Welcome!
Read this...Please DO NOT double post again...
https://mustangforums.com/forum/5-0l...bers-read.html
Well have you checked to see if you get voltage across the solenoid when you turn the key? Do you have the wire hooked up from the ignition switch?
projectresto83 is offline
Old 11-20-2011, 11:41 AM
nitrous_bob
nitrous_bob's Avatar
there should be a "valet" switch somewhere.....it will override the kill switch in the alarm. you press a button and try to start it. but you need to know where it is
nitrous_bob is offline
Old 11-28-2011, 04:28 PM
soulfried
soulfried's Avatar
Default ...........
Getting power from the solenoid, starter reacts when crossing the bolts with screwdriver. Only get the initial click when turning the key though. Been searching for bad grounds, but no luck so far.
Sorry about the double post, computer froze the came back. Didn't realize the first one went through.
Thunderball
15
11-22-2015 11:49 PM
Dathan
10-05-2015 05:52 AM
NYstang
09-30-2015 09:56 PM
mustangheaven
09-29-2015 11:00 AM
Quick Reply: AT a lose, need some help.
