Mach 460 problem
Old Feb 24, 2012 | 01:01 PM
backhomer's Avatar
backhomer
Default Mach 460 problem
I have a 94 gt convertable with the 460 system ( no CD player) I have changed amps, with ones from another car and makes no difference will not work, you can here sounds from speakers but no volume. The fuse panel fuse is fine based on what the internet tells me. The fuse just seems to small 15amp to run radio and all else. Is there a in line fuse or fuse link someplace or amd I chasing a ghost? Thanks
Old Feb 24, 2012 | 01:55 PM
AdderMk2's Avatar
AdderMk2
Banned
Wrong forum.
Old Feb 24, 2012 | 05:29 PM
backhomer's Avatar
backhomer
thanks
Old Feb 25, 2012 | 11:06 AM
jthorn9's Avatar
jthorn9
The Godfather
There are no in line fuses with the Mach 460. Either you have a short in one of the wires or your head unit is bad.
Old Feb 25, 2012 | 12:45 PM
ttocs's Avatar
ttocs
yes there are fuses with the mach system. Did you check the one fuse you thought was the correct one or all of them? If you have not checked every fuse I would go out and do it as you would be suprised how often the fuse popped is not the one you thought it was.
Have you checked for power on the amps with a Volt meter? That would tell us if its the amps or the deck.
Big Al's 03
Sep 16, 2015 07:31 PM
Big Al's 03
Sep 15, 2015 09:05 AM
TimeLord101
Sep 4, 2015 09:27 AM
iamgobono
Sep 3, 2015 12:37 PM
