help please
Old Apr 5, 2012 | 07:07 PM
latinmustang90's Avatar
latinmustang90
Default help please
I recently took the head out of my motor cause one valve broke i wasn't getting any compression on #5 and make little dings in the top of the piston could this be a problem or can I just reinstall the head after is fix please I need some advise please here is a pic...
Old Apr 5, 2012 | 07:22 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
Not being able to see the pics, I don't see why you couldn't.
Old Apr 5, 2012 | 07:32 PM
latinmustang90
ok now you can check them out sorry !
Old Apr 5, 2012 | 08:27 PM
mattdel's Avatar
mattdel
Take a small file and smooth off the edges of the burrs, it'll be fine. Even some fine grit sandpaper...
Old Apr 5, 2012 | 08:47 PM
latinmustang90
do I need to resurface the cylinder head? the engine only has 2350 miles is a remanufactured engine
Old Apr 5, 2012 | 08:51 PM
mattdel's Avatar
mattdel
Shouldn't have to, no. Clean up the gasket mating surfaces with a non abrasive material and that should be all you need.
Old Apr 5, 2012 | 09:01 PM
latinmustang90
thank you very much appreciate your help
Old Apr 5, 2012 | 09:09 PM
latinmustang90
this engine damage should be cover by warranty ? I call the shop where I got the engine from and they say as I install the engine and Im not a certified technician that voids the warranty and I never got any warranty papers what should I do?
Old Apr 5, 2012 | 09:37 PM
mattdel's Avatar
mattdel
They are correct. Any warranty claims must be filed by a licensed shop, and the shop has to be the one to install it originally. You're pretty much screwed there, unless you have a buddy who owns a shop.
Old Apr 5, 2012 | 10:41 PM
latinmustang90
bump !! I dont I guess my only hope is that this thing keeps compression otherwise I may have to junk it along with the car... thanks for the info
