One day to die...help
Yes it should, but that's quite a purchase to justify for a small sensor. Really not complicated at all to replace. There's a tech article around here somewhere where AdderMk2 shows how to disassemble and re-stab it.
well got the new dizzy in, still cold on the driver side (8 and 5)... matt mentioned a limp mode by the computer? is it possible it needs to be reset? im really unsure of what i need to look at next on this so any help is great
Gonna need to see if you have injector pulses on any of the dead cylinders. That will help narrow down. Go see if you can rent this: http://www.autozone.com/autozone/acc...er=948078_0_0_
should be able to od that today. also my check engine light finally came on after trying to run for a bit so ill try and get a code reader on it as well. thanks for stickin with this thread matt, tryin not to let this car beat me hahah
No you dont. You need a paper clip. http://sbftech.com/index.php?PHPSESS...5&topic=2471.0 and http://sbftech.com/index.php?PHPSESS...c5&topic=849.0
