Need Help! Bucking And Bad idle
ok i have a 86 5.0 5-speed. its stock engine wise. Ok ill be just cruising at a constant RPM and all of the sudden it starts bucking, bad. If i floor it it runs great, no hesitation at all. Most of the time when the bucking starts it my idle surges from like 900 to 200 and sometimes dies. I replaced the TPS and that helped for a lil bit but now its back. Do you guys think it can be a baffle issue in the gas tank? Also when i run it hard there will be pressure build up in the tank. I dont want to start spending money on stuff i dont know.
EGR valve is very faintly stuck open by carbon deposits, constant cruising RPM opens it further but the position sensor is registering higher opening than commanded by the PCM, so it compensates by reclosing it, causing a bucking.
Edit: Just realized I forgot about the idle issue. Might be related, might not. Need more info. Disregard what I wrote for now, I'll be back in a few hours.
KingRando
10-02-2015 08:06 AM
