Clunk/Pop in Front end
Old 07-01-2012, 01:45 PM
ryan_89_mustang
ryan_89_mustang's Avatar
Default Clunk/Pop in Front end
I have this noticeable loud clunk or pop when i am turning the wheel at low speed or when I hit the brakes hard or stop when parking or something(normally when backing up).
I have sized up everything I could think of.
I also have a creaking which I have located to the outer tie rod ends. There doesn't appear to be any play they just seem to be dry. I am going to replace those and possibly the inners if they make noise when i get the outers off. Does anyone have any advice on replacing the inners. I haven't been able to find specific information. Like whats the deal with those small rivet looking things and is it necessary to use the tool?
ryan_89_mustang is offline
Old 07-01-2012, 02:31 PM
mgmuscari
mgmuscari's Avatar
That sounds like ball joints to me!
mgmuscari is offline
Old 07-01-2012, 02:51 PM
ryan_89_mustang
I was looking for play there but I couldn't find anything I will take another look though. Thanks
Old 07-01-2012, 07:39 PM
Js88lx
Js88lx's Avatar
i had same prob specaily when i wen backing up!! Checked everything and no one could point it out.., ended up being my struts!!
Js88lx is offline
Old 07-01-2012, 08:14 PM
mattdel
mattdel's Avatar
jack underneath the control arm and use a prybar under the tire to find the play.
mattdel is offline
Old 07-01-2012, 10:05 PM
ryan_89_mustang
What part of the strut was causing it? or were they just wore out?
I will try the method with the pry bar tomorrow morning when I start working on it again. Thanks
Old 07-02-2012, 12:54 PM
Js88lx
Js88lx's Avatar
They where leaking out,, they where shot! I would have strut oil on my fenders behind the front and rear tires, check that.
Js88lx is offline
Old 07-02-2012, 03:22 PM
ryan_89_mustang
Turns out it was the strut in a way. The caster adjustment on my strut was slacked off causing the strut to slide forward and back. I didn't notice it before because I didn't have a jack under the control arm to take the strain off the suspension. So that takes care of that all I need now is an alignment.
New issue though I was looking into replacing the struts since the car is lowered and its still running stock ones. I have heard that Fox struts are better for lowered SN95's is this true?
Also would running a different strut require the car to be realigned even though the ride height is established by the springs?
Thanks guys
Old 07-02-2012, 04:20 PM
Old Mustanger
Old Mustanger's Avatar
If you are going to replace the outer tie rods, you obviously need to replace those before your alignment. If they are dry & noisy, they will go out shortly.
Before your alignment, check out your ball joints well and your Lower Control Arm pivot bushings. They are a very common problem with SN95s. I ended up buying complete new LCA assemblies (with ball joints & bushings) that are for a newer Cobra because they had a better designed pivot bushings. My SN95 only had 50k miles on it.
The 2 LCAs cost under $400 complete.
Old Mustanger is offline
Old 07-03-2012, 05:00 PM
Js88lx
Js88lx's Avatar
yes, i would re-align after new struts!!!
Js88lx is offline
Quick Reply: Clunk/Pop in Front end
