burning oil!!
hey i have an 85 stang 302 5sp. its been smoking alittle bit out of the valve covers, like out of the breathers. I changed the oil but its still doing it. Motor has about 140,00mi. Should i take it in for a valve job, or replace the heads. btw would a set of 74 stang 302 heads fit my 302? thanks
i think you mean oil control/oil scraper rings are bad. they would cause blowby, not the compressionn rings, if the oil control ring is working in any particular cylinder then the oil wouldnt get to the compression ring.
lincolnshibuya
Dec 8, 2015 04:37 PM
