331 stroker
Old Apr 20, 2003 | 10:49 PM
oneblacksvt's Avatar
oneblacksvt
Default 331 stroker
Anyone on here have one? If so did you build it yourself? How much machining is needed for crank clearance?? I have a square deck .30 over 302 block that needs a new crank. Taking it apart so I might as well build the hell out of it.
Old Jan 14, 2004 | 03:53 AM
yardbird's Avatar
yardbird
Default 331 stroker
hey hows it going.I built a 347 stroker 2 years ago and i didnt have to grind much off at all at the bottom of each cylinder sleave and i think a little where the oil pump mounts i cant remember.I used a dremel for the grinding. I relied on information from books and some articles from muscle mustangs and fast fords and also 5.0 magazine.I know that there is a new book out called how to build big inch ford small blocks that would probably be a big help to you.Theweb site is www.cartechbooks.com.I hope this helps.</P>
</P>
Old Jan 14, 2004 | 04:17 AM
baha's Avatar
baha
Default 331 stroker
You don't need any block machining to fit the 331 stroker crank.
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
Brett Ludlow
Sep 23, 2015 06:59 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
YoungStangsMan
Sep 5, 2015 07:01 PM
MonsterBilly
Aug 12, 2015 12:01 PM
